Frigidaire Refrigerator Door Water Dispenser - Appliances - DIY Chatroom Home Improvement Forum
Old 03-31-2008, 06:33 PM   #1
frigidaire refrigerator door water dispenser
the door dispenser won't dispense water, but ice is still being made and dispensed.
rmarkd is offline   Reply With Quote
Old 03-31-2008, 06:45 PM   #2
jeff1's Avatar
Hi,
Model#?
Bad dispensor switch, frozen water tank/reservoir, bad fill valve, broken mechanical mechanism in the dispensor.....would have to be investigated.
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 03-31-2008, 10:15 PM   #3
model# frs6r4eb6
the funny thing is that it worked great until the day we moved. we disconected at our old house and at our new house nothing. it's not
froze up, and when you push the switch it sounds good like it's coming
......then nothing.
Old 04-01-2008, 12:13 AM   #4
jeff1's Avatar
frs6r4eb6
A mostly mechanical style dispensor, easier to service
Where the doors removed? Maybe a line got kinked? Checked the connection where it enters the freezer door at the bottom hinge?
it's not froze up, and when you push the switch it sounds good like it's coming......then nothing.
Maybe an air lock?
Check/remove the filter and reinstall the filter and retest.
jeff.
JRAppliance
www.jrappliance.ca
Old 04-01-2008, 09:53 PM   #5
Smile
you are the man!
in checking if the line got kinked i found a spot between the bottom door hinge and the water outlet that would not let my snake pass by. (i used the line you use on your everyday weedeater to run up the water tube) it was
a frozen resevoir. i thawed it out with a hair dryer and have water again!
many thanks!!!!!
Old 04-02-2008, 12:15 AM   #6
jeff1's Avatar
it's not froze up
it was a frozen resevoir
Yes it was, yes it was
Thankx for the update!
jeff.
JRAppliance
www.jrappliance.ca
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 03:20 PM
Frigidaire Ice/Water Dispenser Metmagic2k Appliances 60 04-18-2011 08:44 PM
Frigidaire fridge water dispenser won't stop nonanon Appliances 1 10-05-2007 09:16 PM
Frigidaire Water Dispenser Won't Stop tharper999 Appliances 6 03-22-2007 08:11 AM
GE Profile Ice Cube Dispenser Problem homebrewer Appliances 1 12-20-2006 11:24 PM
