Frigidaire Refrigerator - Appliances - DIY Chatroom Home Improvement Forum
Old 09-07-2013, 04:06 PM   #1
Frigidaire refrigerator
Model No. FRS26R4A side by side 11 years old.
Water dripping from ice maker which then is leaking into the ice cube holder. Water eventually seeping out of freezer door.
I'm not an expert but sounds like a thermostat issue?
Homerlion is offline   Reply With Quote
Old 09-08-2013, 08:07 AM   #2
Rewards Points: 1,300
If the water is continuously leaking I would suspect the solenoid valve is leaking. If it is intermittent then I would suspect that it is overfilling
danpik is offline   Reply With Quote
Old 09-08-2013, 08:36 AM   #3
PoleCat's Avatar
Rewards Points: 1,652
Since you have water able to flow out the bottem of the door in a freezer it may be your drain line is plugged.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-08-2013, 08:45 AM   #4
What do I need to do? Is the solenoid valve part of thr the ice maker?
Old 09-08-2013, 09:11 AM   #5
Rewards Points: 14,300
http://www.repairclinic.com/RepairHe...owing-FRS26R4A
Frigidaire refrigerator parts ? Rmello Appliances 8 08-15-2013 02:19 PM
Frigidaire side by side freezer works refrigerator doesn't! Towerdog2 Appliances 11 07-22-2012 09:26 PM
Frigidaire refrigerator not working Jean Pete Appliances 1 06-21-2012 10:21 AM
Frigidaire Refrigerator Icemaker Problem frank ok Appliances 5 06-13-2010 07:57 PM
Frigidaire Refrigerator Noisy cjyphoto Appliances 4 12-28-2008 09:33 PM
