Frigidaire Prof Model Fphb2899lf4 Ice Maker Not Making Ice - Appliances - DIY Chatroom Home Improvement Forum
Old 01-02-2012, 06:02 PM   #1
Frigidaire Prof Model Fphb2899lf4 Ice Maker not making ice
Frigidaire Prof Model Fphb2899lf4 (French door model), Ice Maker not making ice. Stopped working after dumping ice out of draw and returning container. Water dispenser works fine. Pulled ice container out nothing looks frozen No switch inside of draw hole. Under warranty Purchased New in July last year called out one repair and reports part needed not available? What’s up with that? Is there a switch stuck or all electronic? Tks Joe
Joe Hub is offline   Reply With Quote
Old 01-03-2012, 12:53 AM   #2
First thing is the parts are avaliable for your make fridge. Second is the ice maker power on? Did you move the metal wire in the up position? Third is did you plug it back in correclty (all connection tight) after examining it to see if it had a ice blockage? Finally do you hear the fridge make a buzzing or humming noise from time to time indicating the the fridge is calling for water to the ice maker? Might end up needing to replace the ice maker assymbly.
acestarservices is offline   Reply With Quote
Old 01-03-2012, 09:01 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
call the repair company back, that is a model you do not want to DIY unless you have a lot of knowledge with it.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-03-2012, 09:02 AM   #4
#1 HAWKEYE FAN
and yes ALL parts are available
Old 01-03-2012, 09:05 AM   #5
That refrig is a nut job from Frigid'. mannnny prob w/ i/m. they're going back to old style-everything right now in flux. you need to get in touch with Frigid' and wear them out.
Jacques is offline   Reply With Quote
GE Profile side by side ice maker making long icicles that hang over two feet Yogitrek Appliances 0 10-17-2010 08:36 PM
Whirlpool Ice Maker Not Making Ice Kaguirre General DIY Discussions 0 06-22-2010 02:35 PM
side by side Frig, ice maker won't stop making ice Jack Splat Appliances 0 06-06-2010 04:22 PM
GE fridge (older model) motor(?) making a lot of noise as it runs, also leak! liileah Appliances 1 06-24-2008 12:32 PM
Whirlpool Ice Maker has stopped making ice jpetersen5 Appliances 7 04-13-2008 07:13 PM
