Frigidaire Ice/Water Dispenser - Appliances - Page 5 - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 08:44 PM   #61
Originally Posted by wizgi View Post
Wow, that's it. No one has been able to locate it as part of my Kenmore Elite, which I realized is a Frigidaire. That includes RepairClinic. Maybe they were looking under the wrong model number.
To be clear, my issue is that there is no power to the front board. Sears came out and said it was the power board, which I replaced to no avail. It was then that I noticed a small tear in the ribbon cable. So I suspect that this is the source of my issue.
Thanks for the help on this. I will order right away and report back.
Steve
So after ordering a Power Board as suggested by the Sears tech and then ordering a Control Board, the problem was resolved with an $8.00 Ribbon Cable. Thanks for the help in locating the correct part (Sears is still trying to find it). Now it's time to package the unneeded parts to send back.
Steve
Originally Posted by JSplaine View Post
I had the exact same problem happen. Did you get it to work and what
did you have to do?
JSplaine
I have this problem too but I can’t find information anywhere if the harness is the culprit, or one or both board’s switches. I tried to connect the wire harness back but then the ice crusher starts to run until I remove the harness from the board. Any help is much appreciated
Thanks,
Frank
2003 Frigidaire Electrolux MDL# GLRS267ZCB0
Navyvet is offline   Reply With Quote
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 03:20 PM
Water Actuator Frigidaire PLHS269ZCB3 Nazz300 Appliances 2 02-26-2011 02:22 AM
Frigidaire Water Dispenser Won't Stop tharper999 Appliances 6 03-22-2007 08:11 AM
GE Profile Ice Cube Dispenser Problem homebrewer Appliances 1 12-20-2006 11:24 PM
Ice/water underlayment twaters12 Roofing/Siding 11 03-15-2006 08:52 PM
