Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-29-2011, 12:30 AM   #1
frigidaire ice make very slow making ice
first, my ice make stopped working for about two weeks, so i did some research and followed a suggestion the water had possible lost it's prime. i remembered that the water dept. had recently turn off the water supply for repairs and decided to try filling the tray manually. it seemed to have worked and has been making ice ever since, but it's very slow at producing the ice like it used to. in 48 hours it won't fill the ice bucket. is there something else i can try to speed it up. all of the cubes are the normal size, but most are half frosty and the other half of the cube is clear. could that be a clue of what the problem might be. maybe it's not filling the tray the first time and completes filling it the second time??? i would appreciate any help you can give me. i lost my husband last year and he was the "do it all king" and now I'm learning slowly but surly how to fix things. Thanks, Ms. Roy Lynn Myers
roylynn is offline   Reply With Quote
Old 10-29-2011, 09:28 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
take the temp of your freezer compartment. If it is not at least 0 degrees, turn it down colder. If this does not make it produce ice faster, let us know.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
roylynn (10-29-2011)
Old 10-29-2011, 05:08 PM   #3
Thanks, I knocked it down a notch. It was set on the "suggested" temp, with two lower settings. If the first time doesn't work I'll try the second (which is the lowest) setting.
Frigidaire water dispenser - slow flow Handy Dandy Appliances 1 01-19-2011 12:02 AM
Need Basic Circular Saw Tips artlover13060 Carpentry 6 10-26-2010 04:01 PM
Best way to make a roof exit or door? swaff Roofing 5 10-22-2010 02:15 PM
Best way to make 45 degree mitre jig BobS0327 Carpentry 7 09-22-2010 12:53 AM
Making my own concrete (or mortar) edger pieces joeyboy Landscaping & Lawn Care 11 07-18-2007 04:43 PM
