Frigidaire FRS24WSCB Side-by-side. Loud Sounds Of Falling Water Into A Pan? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-22-2008, 12:43 PM   #1
Frigidaire FRS24WSCB side-by-side. Loud sounds of falling water into a pan?
Purchased a used Frigidaire FRS24WSCB side-by-side. (see photo link)
But every hour or so, the fridge has loud sounds of falling water into a pan.
P.S. The wire connections to the door dispenser were cut-off. (see photo link below)
What can be the cause of this annoying sound?
Can a DIY'er fix this problem simply?
HoustonDIY is offline   Reply With Quote
Old 04-22-2008, 03:14 PM   #2
jeff1's Avatar
Hi,
Any chance the icemaker is on ( arm is down ) without the water being hooked up to the refrigerator? The fill valve will make a buzzzzzing noise every once in a while when no water is hooked up.
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
House makes loud popping sounds at night michboddy Building & Construction 25 01-20-2015 05:17 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 03:20 PM
Noisy Frigidaire side by side EZ Rider Appliances 7 03-12-2008 01:51 PM
Frigidaire Water Dispenser Won't Stop tharper999 Appliances 6 03-22-2007 08:11 AM
