I have a Frigidaire Front loading washer model FTF530FS1 it has developed a leak which appears ot the floor bottom left when looking at the washer. the leak only occurs when the fill cycle is in progress. when i remove the bottom frnt panel and look up inside the casing i can see water dripping from around the soap dispenser area . I am not sure wether this is excessive splashing or a leak but it only happens when the water is going into the soap dispenser. Any ideas? Thanks
