-   -   frigidaire front loading washer (http://www.diychatroom.com/f47/frigidaire-front-loading-washer-91450/)
jim killen 01-05-2011 08:32 PM
I have a Frigidaire Front loading washer model FTF530FS1 it has developed a leak which appears ot the floor bottom left when looking at the washer. the leak only occurs when the fill cycle is in progress. when i remove the bottom frnt panel and look up inside the casing i can see water dripping from around the soap dispenser area . I am not sure wether this is excessive splashing or a leak but it only happens when the water is going into the soap dispenser. Any ideas? Thanks
hardwareman 01-05-2011 10:49 PM
there should be a hose that runs from the dispenser to the tub, sometimes these devolop small leaks from the vibration of the machine
