Frigidaire Front Loader Leaking - Appliances - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 10:52 PM   #1
Frigidaire Front Loader leaking
We have a 4 year old Frigidaire Front Loader Washing Machine (ATF7000FS1) that has developed a leak on the bottom of the machine. It continues to leak even when the machine is not running. It forms a puddle on the right side when you are looking at the machine. It is a substantial enough leak that the carpet outside of the laundry closet is wet in a patch maybe 2.5 feet x 1.5 feet despite our mopping up the wetness when we remember/notice. This has been going on for about 5 days.
The hoses/connections look ok, from what we can tell. One hose has a very slow/small drip where it connects to the machine, but no way that drip is causing the puddle to form. In the span of 20 minutes, a new puddle will start to seep out from under the machine, even though we just wiped up the area. My husband says the entire bottom panel of the machine feels wet. The problem is, access to the machine is tricky. We stacked our dryer on top in our laundry closet. It's not that simple to just take everything down to hunt for the problem.
Any idea what the problem could be? Or should we just call a professional? We are complete novices. We did stack the dryer ourselves and reconfigure the laundry closet ourselves, but that didn't require a ton of plumbing or appliance know how.
FYI, Tuesday, our home was treated for bedbugs, which means the entire house was heated to 150 deg and held there for 2 hours. We have no idea if that is related to the leak, but the leak started around then. In none of the preparation literature for the treatment did they mention prep for appliances like a washer or dryer.
BTW, hi, I'm new here.
Last edited by jniter; 01-15-2012 at 10:56 PM. Reason: add detail about leak/puddle
jniter is offline   Reply With Quote
Old 01-16-2012, 08:12 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
I would suggest calling a repairman, unit will need to be unstacked to work on the washer. He will have to remove the rear panel, maybe the front panel. Not easy units to work on, everything is cramped and hard to get to.
I would say that the temp had nothing to do with your leak, just coincidence.
I've seen lots of tub to pump hose leaks on these machines. A piece of wire or a nail or pin gets down into the hose and punctures it making a leak, just my first thought .
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Water leaking under front door cm8567 Windows and Doors 6 09-16-2011 10:26 AM
Need to replace front door, existing door non-standard size uncle Windows and Doors 1 07-25-2011 06:50 AM
Ceiling for cistern under front porch T-Bar Building & Construction 3 02-08-2011 12:31 PM
Front landing leaking into basement when it rains cwyse Building & Construction 7 02-27-2010 08:36 AM
Air leaking around front door sadears Building & Construction 13 12-22-2009 06:52 PM
