Frigidaire Fridge Not Getting Cold - Appliances - DIY Chatroom Home Improvement Forum
Old 07-07-2013, 07:34 PM   #1
Rewards Points: 878
Frigidaire fridge not getting cold
Our fridge is about 7 years old and noe the fridge is not getting cold. The freezer works fine. Any troubleshooting i can DIY to try and find out whats going on? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 07-07-2013, 08:18 PM   #2
Rewards Points: 6,652
Freezer is fine, that means that you most likely have ice clogging the duct between the fridge and freezer. Time to unload it, then grab a Phillips screwdriver to remove the bottom plate out of the freezer, and then you should be able to remove the duct on the back.
That is assuming that it is a upright with freezer on top, since you did not state model of the freezer, or post a picture of the unit.
Old 07-08-2013, 07:21 AM   #3
Rewards Points: 878
Side by side and it starting working again. Thanks a lot for the advice!!!!
Old 07-08-2013, 08:38 AM   #4
I would still take the back apart if it is not passing air through. Some have a defroster, some have a fan in that back chamber that passes air through the damper between freezer and fridge.
Ice is the main culprit that causes this problem.
Old 07-24-2013, 05:00 PM   #5
Rewards Points: 878
Sorry Greg for the delay....thanks.
Warm Water out of Cold Water Outlet mb0709 Plumbing 9 08-26-2012 12:59 PM
Do I need this cold air return, pictures shown steffen707 HVAC 8 01-18-2012 02:39 PM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
