-   -   Frigidaire fridge not getting cold (http://www.diychatroom.com/f47/frigidaire-fridge-not-getting-cold-183225/)
Mstrlucky74 07-07-2013 07:34 PM
265 Attachment(s)
Our fridge is about 7 years old and noe the fridge is not getting cold. The freezer works fine. Any troubleshooting i can DIY to try and find out whats going on? Thanks
gregzoll 07-07-2013 08:18 PM
Freezer is fine, that means that you most likely have ice clogging the duct between the fridge and freezer. Time to unload it, then grab a Phillips screwdriver to remove the bottom plate out of the freezer, and then you should be able to remove the duct on the back.
That is assuming that it is a upright with freezer on top, since you did not state model of the freezer, or post a picture of the unit.
Mstrlucky74 07-08-2013 07:21 AM
265 Attachment(s)
Side by side and it starting working again. Thanks a lot for the advice!!!!
gregzoll 07-08-2013 08:38 AM
I would still take the back apart if it is not passing air through. Some have a defroster, some have a fan in that back chamber that passes air through the damper between freezer and fridge.
Ice is the main culprit that causes this problem.
Mstrlucky74 07-24-2013 05:00 PM
265 Attachment(s)
Sorry Greg for the delay....thanks.
