#1 |
Frigidaire fridge not cooling
FRS20ZRG, Ok I have tested the sensor for continuity and examined it for seepage, no issue , continuity checks ok, dismantled the timer and polished the charred contacts, watched the timer advance after reassembly, etc. Seems to advance as I marked it with a felt tip pen.
Also ran the ohm meter on the heater element, but not sure if it is reading .80 to .85?, or 80 as I am not familiar with the OHM scale. When I bypass the sensor and plug the element in direct, then advance the timer until it clicks, there is no sign of the element glowing or causing ice to melt. When I manually defrost the fridge cools again as the blower can move cool air to the fridge side. Did I miss anything or does anyone want to give me more pointers on how else to test the heater versus the timer and the sensor. |
#2 | |
Frigidaire fridge not coolingQuote:
#3 |
Thanks, tested the stat for continuity earlier but not resistance but I can dismantle again after I test the timer I rebuilt today. Open to any other suggestions. The timer is cycling for sure so I will run overnight and check tomorrow.
#4 |
HVAC / Plumbing
Timer is only a switch. Should have little to no resistance
#5 |
done!, Ohmed the heater , was uncertain so ran a continuity test, and no beep!! Installed the heater yesterday, back on track. Darn cooling fins are a sharp!!!! Thanks for the pointers as I expected it was the heater.old one fel appart during removal
| Display Modes | |
| Help My Admiral Refrigerator is leaking water | Cuwillis | Appliances | 9 | 03-22-2011 09:40 PM |
| Kenmore fridge stops cooling with frost in freezer | donnoit | Appliances | 3 | 09-20-2010 08:59 AM |
| Kenmore fridge not cooling, freezer ok | bobvanhalder | Appliances | 20 | 10-23-2008 12:36 AM |
| Kenmore fridge not cooling, freezer ok | bobvanhalder | HVAC | 7 | 10-22-2008 11:52 PM |
| Fridge not cooling - evap fan? | oppiecat | Appliances | 3 | 12-06-2006 07:46 AM |
