-   -   Frigidaire fridge not cooling (http://www.diychatroom.com/f47/frigidaire-fridge-not-cooling-82622/)
Chemist1961 09-29-2010 09:57 AM
FRS20ZRG, Ok I have tested the sensor for continuity and examined it for seepage, no issue , continuity checks ok, dismantled the timer and polished the charred contacts, watched the timer advance after reassembly, etc. Seems to advance as I marked it with a felt tip pen.
Also ran the ohm meter on the heater element, but not sure if it is reading .80 to .85?, or 80 as I am not familiar with the OHM scale.
When I bypass the sensor and plug the element in direct, then advance the timer until it clicks, there is no sign of the element glowing or causing ice to melt.
When I manually defrost the fridge cools again as the blower can move cool air to the fridge side.
Did I miss anything or does anyone want to give me more pointers on how else to test the heater versus the timer and the sensor.
del schisler 09-29-2010 01:35 PM
go here and read about how to test. The defrost heater just get's warm. It doesn't glow red. That probly what's wrong. If it ice's up. the heater probly is bad. Did you take the wire off of one end when you measured it? http://www.partselect.com/refrigerat...arm+repair.htm
Chemist1961 09-29-2010 08:45 PM
Thanks, tested the stat for continuity earlier but not resistance but I can dismantle again after I test the timer I rebuilt today. Open to any other suggestions. The timer is cycling for sure so I will run overnight and check tomorrow.
kenmac 09-30-2010 07:01 AM
Timer is only a switch. Should have little to no resistance
Chemist1961 10-09-2010 01:42 PM
Fridge repair update
done!, Ohmed the heater , was uncertain so ran a continuity test, and no beep!! Installed the heater yesterday, back on track. Darn cooling fins are a sharp!!!! Thanks for the pointers as I expected it was the heater.old one fel appart during removal
