Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-07-2012, 09:56 PM   #1
LensGrinder's Avatar
Frigidaire Freezer Problem
Hello all!!! I have a Frigidaire stand up freezer that is not freezing food. The interior walls are very cold, but it doesn't keep anything frozen. Does anyone have any idea what is the problem. Thanks
LensGrinder is offline   Reply With Quote
Old 08-07-2012, 10:32 PM   #2
Whats the interior temp at currently? Is there any water on the outside of the unit? Is the door seal and hinge in good working condition? Bad seal will definitely cause a warm freezer.
Is this a fridge/freezer combo? or just a freezer?
Protocol. is offline   Reply With Quote
Old 08-07-2012, 10:42 PM   #3
The dial is on 7 or 8. There is no water leaking & the seal is good. I was wondering if it was the thermostat or the fan, but the fan still seems to be running fine. It's a freezer only.
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 09:32 AM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 07:35 PM
frigidaire FRS26HF6DB2 Ice Problem javan Appliances 3 01-11-2011 09:07 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
