Frigidaire Fef369cgsd Oven Not Working - Appliances - DIY Chatroom Home Improvement Forum
Old 04-20-2014, 02:56 PM   #1
frigidaire fef369cgsd oven not working
Hey all,
The other day I was using the bake feature and saw this little button that said "speed bake". Being the curious person I am, I flipped the switch. When I did, I saw a bright spark and heard a pop on the upper left side of the stove. It also tripped the breaker at the fusebox. After checking everything, I flipped the breaker back on and the stove went back to normal.
Ive used the stovetop several times and everything appears to work properly. However, today, I chose to bake and it didn't work. The broiler doesn't work either. I did test the elements with an ohmmeter and they check out as fine. I removed the back of the stove and noticed that there was one piece of plastic that said "220v" that is burned. It looks like this box is hardwired in (the wires coming to it appear to be soldered on). I did test this box (its coming off the element knobs on the left side of the stove and terminates to the white box stamped 22504 220v) and it shows continuity.
Do I need to get a new stove?
97runner is offline   Reply With Quote
Old 04-20-2014, 03:31 PM   #2
Rewards Points: 6,652
Something went bad inside the stove. Do not know why you pulled the DMM out and risked endangering yourself or the house.
Depending on the model and how old. Would depend on if parts are available. If the short burnt up any wiring, yes you would most likely need a new stove.
Call a local Appliance repair place to check it out, to see if it is even worth repairing.
Old 04-20-2014, 03:42 PM   #3
The model has been discontinued (I have no idea how old it is, it came with the house). It sounds like I just need to spend more money in my new found money pit (oh the stories I could tell...) and buy a new stove.
Old 04-20-2014, 04:34 PM   #4
Rewards Points: 14,312
http://www.repairclinic.com/RepairHe...on--FEF369CGSD
Old 04-20-2014, 04:41 PM   #5
Thanks, Joe. I saw that site. I tested both elements and they have continuity. I am also getting continuity at all the points where I should be. The odd place is the burnt out box on the upper right side (back of stove). I've traced the wires to what would be the "bake" button. I have continuity at the origin (where the button is), but where it terminates (the white "box") I do not. Im guessing that this burnt out whatever that white box is. It looks like a fuse box, but the glass element inside appears to be ok. If I could find a replacement part, Im sure it would be inexpensive. But finding that part is shaping up to look like it won't happen.
Im going to stop by my local small appliance repair shop tomorrow and see what they suggest.
Old 04-21-2014, 02:03 AM   #6
Rewards Points: 744
That's a convection oven. "Speed Bake" turns on the fan.
The little white box is an indicator light. It likely tells you speedbake is turned on. The part# 22504 = 316022504. This part has been replaced by part number 3016022503
http://www.repairclinic.com/PartDeta...mber=316022504
RC has it in stock, $26.60. If that part blew, and your breaker tripped, I would certainly check for a shorted connection somewhere in the range. The oven control board may also be damaged as a result.
Seattle2k is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Frigidaire Dishwasher not working Justins1171 Appliances 6 12-05-2011 08:20 PM
oven door seal replacement, self-cleaning function malfunction YerDugliness Appliances 10 02-28-2011 09:22 PM
Clearance for double oven installation Steeler99 Building & Construction 1 01-30-2011 05:16 PM
Wall oven too Wide for Cabinet victor07 Carpentry 8 01-02-2011 11:09 PM
