Frigidaire Door Hinge Broken!!! - Appliances - DIY Chatroom Home Improvement Forum
Old 04-05-2009, 12:05 AM   #1
Question
Frigidaire door hinge broken!!!
Hello,
My refrigirator by FRIGIDAIRE Model# PLHS269ZCB3 door hinge at the bottom is broken. Can I detach the door and replace the broken hinge? Is there anyone who had the same issue as me? Thank you in advance!!
bmgg is offline   Reply With Quote
Old 04-05-2009, 09:44 AM   #2
Rewards Points: 5,336
If the hinge just broke, it's an easy fix. Remove everything on the door and unscrew the hinge. put a new one on.
If the hinge ripped out of the frame or door, it becomes a more involved issue.
Ron
Old 04-05-2009, 06:26 PM   #3
Yep Ron is right just replace it (about $25 new), but if it is a side by side and the freezer side is broke the ice & water controls have a fair amount of wiring coming into the door right near that lower hinge. If the pin broke off and you still have the pieces you can drill and tap it, actually pretty easy to do. Or if the piece is missing and don't want to spend the money a 1/4x20 bolt could be tapped into the bracket as a jury rig.
hychesee is offline   Reply With Quote
Old 04-05-2009, 09:58 PM   #4
Please see this picture
Thank you Ron and Hycheses!
Could you take a look at this picture and confirm the problem?
I don't know what the exact part number is.
Thank yo very much again
Old 04-05-2009, 11:02 PM   #5
Door closing cam, part number 891712 - $5.90 plus shipping
http://www.repairclinic.com/SSPartDe...&PartID=891712
Old 04-05-2009, 11:16 PM   #6
Great!!!
Thank you so much!!
Making a patio from broken granit slabs need help BJLower Tiling, ceramics, marble 9 09-15-2014 12:15 PM
broken pipe under cement atichargr Plumbing 5 04-23-2009 11:15 AM
broken lug studs LanterDan Automotive Repairs 19 02-01-2009 08:13 PM
Broken floor flange for toilet billy Plumbing 10 03-13-2008 07:58 PM
Broken Drill Bit Freelancer General DIY Discussions 15 03-29-2007 04:01 PM
