Frigidaire Dishwasher Not Working - Appliances - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 07:45 PM   #1
Rewards Points: 77
Frigidaire Dishwasher not working
I know this is going to sound a bit ridiculous, but two years ago I moved into my new home and decided to bring the dishwasher from the old house. No problems before the move. The dishwasher isn't working. There are no signs of lights or sounds when the unit is plugged in and I feel that I've gone long enough without my dishwasher Looking for instructions on how to diagnose the problem and where I might look for replacement parts.
Justins1171 is offline   Reply With Quote
Old 12-05-2011, 07:47 PM   #2
Rewards Points: 582
check to make sure you have power to the unit...unplug it and plug something in to outlet that you know works..see what happens...
Old 12-05-2011, 08:00 PM   #3
Rewards Points: 77
I did try that. No change in the unit. I have also checked to ensure that the receptacle was wired properly and didn't fry the dishwasher
Old 12-05-2011, 08:04 PM   #4
Rewards Points: 582
I guess you have power at plug....check were cord gos into diswasher maybe in move got pulled...also check door switch push on top of door and see if that works. again maybe door got damaged in move...
Old 12-05-2011, 08:14 PM   #5
Rewards Points: 77
The door does securely close
Old 12-05-2011, 08:18 PM   #6
Rewards Points: 582
those are the most obvious that i can think of ..you may need to get a tech out to make sure you have power into the inlet box then make sure you have power to timer assy....don't think you can perform that test...sorry
Old 12-05-2011, 08:20 PM   #7
Rewards Points: 77
Thanks. I appreciate it.
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 10:45 AM
Electrical Line To Dishwasher - Faulty?? mike6679 Electrical 19 09-30-2011 01:37 AM
Lights Blinking on Frigidaire Dishwasher used2beatech Appliances 3 01-25-2010 07:09 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 04:28 PM
