Frigidaire Dishwasher Not Drained - Appliances - DIY Chatroom Home Improvement Forum
Old 08-15-2008, 04:01 PM   #1
Frigidaire Dishwasher not drained
I have a Frigidaire Dishwasher (model # fdb750rcc0 ) that is about 4 years old. It worked well. But now it can not drain, though I see the timer still rotates. Water is left inside all the time.
I'd like to know what can be the reason, and how to check (by multimeter, etc) before go to buy the new drain motor and try.
Any and all help is appreciated.
llilipop is offline   Reply With Quote
Old 08-16-2008, 05:43 AM   #2
jeff1's Avatar
Hi,
This d/w has two motor and pump assemblies. One for washing and one for draining.
Drain motor and pump ( right side near the back ) assy receives 120 volts and runs to pump out the water. Power to the drain pump and no go = a bad drain pump or something stuck/jammed inside the drain pump. No power to the drain pump, and the wiring or timer is suspect for not allowing/sending power to drain pump assy.
If needed:
Drain pump kit
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 08-16-2008, 08:36 PM   #3
Thanks, Jeff. That's very helpful. I did check and will order a new pump.
Old 08-17-2008, 07:43 AM   #4
jeff1's Avatar
If you get a chance, let us know how the repair goes.
jeff.
JRAppliance
www.jrappliance.ca
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 07:55 PM
Removing A Dishwasher jte1130 Plumbing 13 05-29-2008 09:49 AM
Dishwasher Wiring mcpusc Electrical 1 04-28-2008 08:19 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 04:28 PM
