Frigiadire Electric Stovetop Burner Won't Go Off! - Appliances - DIY Chatroom Home Improvement Forum
Old 08-03-2009, 05:49 PM   #1
Frigiadire burner electric burner won't turn off. After I used the large front burner, it won't turn off. I turned it off, but it keeps cycling on (red hot).
I can't unplug it....what can I do?
limitdiy is offline   Reply With Quote
Old 08-07-2009, 11:36 PM   #2
If you haven’t already unplug the stove or pull the breaker. Once the unit cools off you can unplug the unit (most of them just unplug). The surface unit switch is what is causing this problem.
Last edited by Scuba_Dave; 09-30-2010 at 11:36 AM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
monitor heater repair help speakers3 HVAC 16 01-18-2015 04:00 AM
Is my panel sufficient to add Electric water heater andy Electrical 16 04-21-2009 08:34 AM
Oil burner will not stay on Coldman HVAC 12 04-01-2009 10:12 PM
Broken Burner Fix mikelbeck HVAC 2 01-16-2009 09:05 PM
Question about gas burner design darsunt HVAC 4 12-14-2008 01:37 PM
