Frige Stopped Cooling But Freezer Still Works. 1196 Kenmore Coldspot. Defrosted Freezer As Ice Granules On All Interior Stuff. - Appliances - DIY Chatroom Home Improvement Forum
Old 11-14-2011, 06:28 PM   #1
frige stopped cooling but freezer still works. 1196 kenmore coldspot. defrosted freezer as ice granules on all interior stuff.
My kenmore coldspot stopped cooling but Freezer still works. had to defrost, as ice formed on most of the interior stuff. Have had problems with water spillage at bottom of refrig (on the inside)What 's the problem
Dmanyhorses is offline   Reply With Quote
Old 11-14-2011, 06:37 PM   #2
Too Short? Cut it Again!
Have you cleaned the drip pan underneath the frig that catches water? Some times just vacuuming dust from the coils underneath and/or in back will fix the problem you describe as well. Don't mean to insult you but I am notorious for not checking the obvious first. You didn't accidentally hit the temp controls with a milk bottle or something.
The Following User Says Thank You to user1007 For This Useful Post:
keebo65 (11-17-2011)
Old 11-15-2011, 11:06 AM   #3
Your defrost system isn't working. Either your defrost heater or defrost thermostat. once enough ice builds up it blocks the air flow into your fridge.
jfrotten is offline   Reply With Quote
The Following User Says Thank You to jfrotten For This Useful Post:
