Frigadaire Water Dispenser Wont Stop Turning On - Appliances - DIY Chatroom Home Improvement Forum
Old 05-23-2008, 01:14 PM   #1
Question
Frigadaire water dispenser wont stop turning on
I have a side by side Frigidaire refrigerator and the water dispenser in the door will come on at random and dump out half a glass of water then turn off.
The ice maker isn't making much ice either. Can anyone give me any idea why this is happening?
happygolucky is offline   Reply With Quote
Old 05-23-2008, 01:37 PM   #2
jeff1's Avatar
Hi,
Model#?
http://www.applianceaid.com/model.html
By itself? If yes, sticky/bad switch, bad electronic dispensor board ( if used on your model ), ice or moisture inside the shorting out, poor/low water pressure causing the fill valve to stay open.
Make sure the freezer temp is below 15F to cycle the icemaker on and low/poor water fills will also cause slow ice production.
jeff.
Appliance Repair Aid
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 05-23-2008, 01:50 PM   #3
Sorry the model # is frs6r4eb7
It comes on by itself every 30 minutes or so. It kinda makes me think that the water that is coming out is actually meant for the ice maker but instead is coming out the door. Is that possible?
The fridge was manufactured in Oct 06
Old 05-23-2008, 07:47 PM   #4
jeff1's Avatar
frs6r4eb7
If all else checks ok, this unit has the dreaded Frigidaire diodes in the icemaker and chilled water wiring. These are suppose to pass power in one direction only and if shorted the chilled water can come on when the icemaker is calling for water or the icemaker can over fill when someone is getting a glass of water
Diodes don't show in the parts breakdown, may need to call local parts depot to check on them if needed.
jeff.
JRAppliance
www.jrappliance.ca
Old 05-26-2008, 08:30 AM   #5
Here is the part number 5303918287 for the diode wiring kit for you fridge model frs6r4eb7.
You can get you Frigidaire parts here.
girltech is offline   Reply With Quote
Old 05-26-2008, 06:32 PM   #6
jeff1's Avatar
A part#
Diode repair kit, water valve wire harness
jeff.
JRAppliance
www.jrappliance.ca
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Turning off water RachelS Plumbing 2 02-06-2008 04:02 PM
Frigidaire fridge water dispenser won't stop nonanon Appliances 1 10-05-2007 08:16 PM
Frigidaire Water Dispenser Won't Stop tharper999 Appliances 6 03-22-2007 07:11 AM
turning off water Jack Hass Plumbing 1 02-03-2007 09:00 PM
