Frigadaire Water Dispenser Not Working - Appliances - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 01:35 PM   #1
When I press the water dispenser button I hear a water flow for a sec but no water is dispensed. The ice dispenser works. When I remove the water filter cover inside the refridgerator and press the water dispenser button, water shoots down so I know it's getting that far. Any clues at all? Thanks so much.
pf1grant is offline   Reply With Quote
Old 11-08-2012, 12:12 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
either a frozen filter or a plugged filter
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
Old 11-08-2012, 12:39 PM   #3
Hi, I replaced the filter after the problem occurred, no change. Any other suggestions?
Old 11-08-2012, 12:43 PM   #4
#1 HAWKEYE FAN
frozen water line maybe, after it leaves the filter it goes directly to the dispenser. Try turning the temp up for a few days
Old 11-08-2012, 12:51 PM   #5
Should I turn it up or down if the line is frozen? Minutes ago I unplugged the frig to see if the line defrost, is that a good idea also? I can only do so for a period of time to ensure the frozon foods do not thaw.
Water is not working Rc51Twin01 Plumbing 7 12-07-2011 10:15 PM
Kitchenaid water dispenser NOT dispensing nvrrong Appliances 7 12-05-2011 09:36 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
