-   -   Frigadaire Water Dispenser Not Working (http://www.diychatroom.com/f47/frigadaire-water-dispenser-not-working-162385/)
pf1grant 11-06-2012 12:35 PM
When I press the water dispenser button I hear a water flow for a sec but no water is dispensed. The ice dispenser works. When I remove the water filter cover inside the refridgerator and press the water dispenser button, water shoots down so I know it's getting that far. Any clues at all? Thanks so much.
hardwareman 11-07-2012 11:12 PM
either a frozen filter or a plugged filter
pf1grant 11-08-2012 11:39 AM
Hi, I replaced the filter after the problem occurred, no change. Any other suggestions?
hardwareman 11-08-2012 11:43 AM
frozen water line maybe, after it leaves the filter it goes directly to the dispenser. Try turning the temp up for a few days
pf1grant 11-08-2012 11:51 AM
Should I turn it up or down if the line is frozen? Minutes ago I unplugged the frig to see if the line defrost, is that a good idea also? I can only do so for a period of time to ensure the frozon foods do not thaw.
