Fried Optic Bord - Appliances - DIY Chatroom Home Improvement Forum
Old 02-11-2010, 10:59 AM   #1
fried optic bord
I preformed routine maintenance vacuuming /filter replacement on ref. 106.52602100. Then there was no ice being made. Checked the optic LED, the light is not flashing. Pulled optic receiver #2198586. The large chip is melted. What are my options for the fix?
mr202 is offline   Reply With Quote
Old 02-12-2010, 09:20 AM   #2
Rewards Points: 6,652
Get a new board through repairclinic.com, a local source, or manufacturer. Not much else you can do. If the chip melted, that means that either the inverter went bad because of poor manufacturing, or you got a surge, which means get a whole house surge protector installed. I lost a stove control board because of a surge, same with a microwave during the 2006 Ice storm. Since we have installed the protector, and pretty much have all appliances with protection strips or outlets, have not had a problem since.
Old 02-12-2010, 05:49 PM   #3
Thanks, now the second board shorted out as soon as the refrig was turned on.
Old 02-12-2010, 07:22 PM   #4
That would be a fridge problem, which means contact the manufacturer. If a newer fridge, then something is wrong. Has any other electronics in the house having problems, or problem with dimming lights?
Old 02-15-2010, 01:09 PM   #5
I haven't seen any other electrical issues. The frig is on its own circuit. All the other electronics are working on the frig. I think it's a 2002 model frig. Is there anything I coud have hit while vacuuming?
Old 02-15-2010, 03:35 PM   #6
Static Electricity built up around the vacuum wand while using it near the board.
Old 02-23-2010, 06:22 AM   #7
I understand the static stuff. I wasn't around the board with the vac and the frig was unpluged. Since the 2nd board is fried I'm at a lost of what to do with it beimg an 02 model. Thanks for your help on this.
min depth for fiber optic cable underground? MusicMan_234 Electrical 5 01-30-2009 01:32 AM
Fried GFCI DirtSquirt Electrical 6 11-07-2008 01:48 PM
My Brain is Fried! movick724 Electrical 7 06-01-2008 12:35 PM
