Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-26-2008, 08:20 PM   #1
Frididaire dryer glides
I had a loud squeel in the dryer and found out i had a bad rear bearing assembly. I replaced it and since i had the dryer open i also replaced the top drum glides. After i finished and turned the dryer on it sounded like a rubbing sound. Is that Normal? If not what could be causing it? The squeek is gone though. The dryer model # is fde336res1 Thanks
sflamedic is offline   Reply With Quote
Old 03-26-2008, 09:25 PM   #2
jeff1's Avatar
Hi,
More like a sciffing or light scratching sound is normal....since we cannot hear your dryer we cannot really say what is happening or not happening.
This might help as well....
Sil-Glyde Lubricant The super film strength, long lasting, clear lubricating compound ( great for dryer rear drum bearings and some dryer front glides ).
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 03-26-2008, 09:57 PM   #3
Figured it out. After a little bit of listening and reading online i lubed the tension pulley shaft and waallaaaaa sound is gone and purs like new. Thanks anyways.
Old 03-26-2008, 11:57 PM   #4
jeff1's Avatar
Thankx for the update!
jeff.
JRAppliance
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 05:33 PM
Dryer vent. kcrossley2 Plumbing 10 02-20-2008 01:02 AM
dryer woes... cisco10 Appliances 3 09-02-2007 04:46 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
