-   -   Frididaire dryer glides (http://www.diychatroom.com/f47/frididaire-dryer-glides-19054/)
sflamedic 03-26-2008 08:20 PM
I had a loud squeel in the dryer and found out i had a bad rear bearing assembly. I replaced it and since i had the dryer open i also replaced the top drum glides. After i finished and turned the dryer on it sounded like a rubbing sound. Is that Normal? If not what could be causing it? The squeek is gone though. The dryer model # is fde336res1 Thanks
jeff1 03-26-2008 09:25 PM
Hi,
More like a sciffing or light scratching sound is normal....since we cannot hear your dryer we cannot really say what is happening or not happening.
This might help as well....
http://www.repairclinic.com/dbimages...6/00126545.jpg
Sil-Glyde Lubricant The super film strength, long lasting, clear lubricating compound ( great for dryer rear drum bearings and some dryer front glides ).
jeff.
sflamedic 03-26-2008 09:57 PM
Figured it out. After a little bit of listening and reading online i lubed the tension pulley shaft and waallaaaaa sound is gone and purs like new. Thanks anyways.
jeff1 03-26-2008 11:57 PM
Thankx for the update!
jeff.
