Fridgidare Side Yb Side Water Dispenser - Appliances - DIY Chatroom Home Improvement Forum
Old 04-22-2013, 08:52 AM   #1
fridgidare side yb side water dispenser
I have a fridgidare mod. glhs66ejsbo side by side. this morning while using ice dispenser, I pushed the extra ice button and water started coming out of water dispenser. the water light did not com on but the dispenser cycled on its own, (all over the floor until I got water supply turned off and internal tank of fridge was empty). the water would run for about 5 seconds , shut off for 5 seconds and so on until I got water supply turned off
dtspec is offline   Reply With Quote
Old 04-22-2013, 06:33 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,598
are you asking a question or just making a statement here?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is online now   Reply With Quote
Old 04-22-2013, 08:02 PM   #3
fridgidare spewing water
this was a question. both the ice and extra ice lights are stuck on. the unit will give ice but the water runs all by itself. (onto the floor) but the water light is not on
Old 04-25-2013, 07:26 PM   #4
I am having issues similar with my frigidaire SBS. I found behind the dispenser are two micro switches that are pretty close together. The switch could be stuck or broken mine was. Now I have issues with leaking water from ice dispenser when I ask for water.
tenlegend is offline   Reply With Quote
Old 04-26-2013, 07:52 AM   #5
fridgidare sbs
I disconnected the microswitch that actually opens the water valve but both the ice and extra ice lights are still stuck on and while water is not coming out now, I still hear a solenoind cycling every few seconds. thinking of replacing both circuit boards in the door
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 10:47 AM
New hookup water and ice dispenser not working billybarty Appliances 6 02-18-2011 08:34 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
