Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-16-2011, 11:47 AM   #1
JPM
Bill Traver
Fridgidaire microwave no power
I have a
FRIDGIDAIRE MICROWAVE
model#: GLMV168KS4 (S may be a 5)
serial#: PG24201278
I have good electric to my socket but when MICRO is plugged in, I get NOTHING ... is there a reset somewhere or a fuse or is this just dead in the water?
Thanks,
Bill
JPM is offline   Reply With Quote
Old 11-16-2011, 12:18 PM   #2
Tileguy
Bud Cline's Avatar
In the absence of your Owner's Manual why wouldn't you look this appliance up on the Internet and see if it has a Reset of some kind?
Old 11-16-2011, 01:16 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
it has an internal 20 amp fuse
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-16-2011, 01:42 PM   #4
JPM
Bill Traver
I looked online for the manual and wiring diagram ... the manual has no mention of anything so thank you for the note about the internal fuse.
Since I do not have any diagram to go from, can you give me an idea of how to access the fuse so I can test/replace?
Thanks !!
Old 11-16-2011, 01:45 PM   #5
I have gas!
Clutchcargo's Avatar
It probably overheated and blew the fuse. Unplug it, pop the cover off and you should be able to track the power line in.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-16-2011, 01:49 PM   #6
JPM
Bill Traver
This is the first time I have ever thought of working on a microwave so pardon my dumb questions, but this thing is mounted to the underside of a cabinet ... there look to be a couple of "cover" spots ... could you point me in the right direction of the one that will have the wiring in it?
Sorry to sound dumb as a stump on this one
Once I get inside, I will be fine ....
Old 11-16-2011, 05:00 PM   #7
Average Joe/ex-Navy IC3
gregzoll's Avatar
JPM, you have to remove the front cover to get to the two phillip head screws holding it to the bracket, then it will lift and you can take it down. Go to the manufacturer website and you should be able to pull the manual there.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 11-16-2011, 06:42 PM   #8
#1 HAWKEYE FAN
before you get carried away with pulling the microwave down, take off the front vent grill. Look for 1 screw that holds the control panel in, remove the control panel. Now you will probably be able to access the fuse. Replace the fuse, you may get lucky and not have any other problem but usually the fuse blows for a reason.
Old 11-16-2011, 08:59 PM   #9
JPM
Bill Traver
Good advice ... I will try pulling the vent and look for one or two screws ... have same thought about the fuse but thought to give it a try anyway.
LOVE the REN AND STIMPY ....nice
Dishwasher Power Supply Captain.Sassy Electrical 14 09-14-2011 06:28 AM
house power supply upgrade in Australia pcd1965 Electrical 3 08-22-2009 09:17 PM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 10:58 PM
Partial power on same fuse! joyjam Electrical 5 07-10-2005 11:23 PM
