Fridgedaire Ice Dispenser - Appliances - DIY Chatroom Home Improvement Forum
Old 11-06-2011, 08:49 AM   #1
Fridgedaire ice dispenser
Panel fell off, ribbon cable unplugged, took apart and plugged in, stuck on dispencing ice, light on also. Checked cable with ohm meter, looks like not broke anywhere, any ideas or thoughts on resetting procedure?
jhdh is offline   Reply With Quote
Old 11-06-2011, 02:51 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
hooked back up wrong
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 11-06-2011, 03:28 PM   #3
Rewards Points: 476
How did you use ohm meter to measure voltage?? The voltage to the little moter is ac voltage and not measured by a ohm meter. I have been in repair for 50 yrs and know meter's. I bet the plug is plug in the wrong way unless it is made to plug in only one way like a bigger end or key way ?? check if it can be plug in the other way change and see if the motor turn's on with the little wire that hangs down?? the wire should be down for the motor to run and for water to flo. good luck
del schisler is offline   Reply With Quote
Old 11-08-2011, 09:23 PM   #4
See Ice Maker Diagnostic Test in mid video. I think all may be similar.
http://www.geappliances.com/videos-m...tegoryid=13814
diyorpay is offline   Reply With Quote
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 02:20 PM
Freezer door ice dispenser freezes up BenW Appliances 2 09-20-2011 03:13 AM
Frigidaire water dispenser - slow flow Handy Dandy Appliances 1 01-18-2011 11:02 PM
how to remove ribbon harness from a fridgedaire side by side water dispenser patrickpersaud Plumbing 0 09-24-2010 09:56 PM
Asko Dishwasher Dispenser came with Different Connections momfxit Electrical 0 09-16-2010 05:33 PM
