Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-23-2011, 07:11 PM   #1
Question
fridge water supply line
if i'm not using my freezer to make ice, can i cut the water supply line ?
Old 09-23-2011, 07:49 PM   #2
Super Moderator
Sure--shut the water off----disconnect and cap the shut off vale in case somebody turns it back on.
oh'mike is online now   Reply With Quote
amakarevic (09-24-2011)
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
Water line to fridge question. ingeborgdot Plumbing 18 11-18-2010 07:45 AM
Water line to fridge, actually -in- 'subflooring', not under?? Anonyone Plumbing 5 10-16-2010 07:31 PM
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 10:20 AM
Extending Water Supply Box In Laundry Room hsl Building & Construction 0 11-18-2009 10:21 AM
