Fridge Rust - Appliances - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 07:57 AM   #1
Fridge Rust
I have a Frigidaire FLSC238DS6 that has a spot rusting through about 3/4 way up on freezer side. It appears to be coming from the inside (Weeping through). All connections in and out seem tight. Have not removed any panels. Any ideas? Thanks. Barry R.
Barry R is offline   Reply With Quote
Old 02-07-2012, 11:13 AM   #2
Somebody has filled the tray under the in door water dispenser with water. It overflowed and made it's way behind the paint. Sand and paint the door or replace it. Then, try to keep that tray dry.
jfrotten is offline   Reply With Quote
Old 02-08-2012, 06:20 PM   #3
Smile
The rust is on the rear of the fridge and its Stainless, not painted. Thanks
Old 02-08-2012, 06:42 PM   #4
Rewards Points: 484
If stainless try some navel jelley or go to a boat company and get some of their stuff. If it is good stainless than that is surface rust and should come off and the stainless should be good as new. If you get it off use some olive oil on the stanless
del schisler is offline   Reply With Quote
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Water buildup in Fridge mibson Appliances 14 12-05-2013 09:02 AM
Cabinet, Fridge, & Pantry fitment mystic_cobra Carpentry 8 01-17-2012 12:36 AM
Fridge Diagnosed as "Unrepairable" Old Lady Appliances 9 06-28-2011 06:08 AM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 06:02 AM
