Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-04-2012, 08:26 PM   #1
Fridge Problem
I have a small GE fridge 4.3 cu ft.. only 15 months old
http://products.geappliances.com/App...Sku=GMR04HASCS
In order for too get it to work you have to turn the thermostat as far as it will go to coldest... if you put it to were it suppose too go, it will not run at all,.
would the thermostat need replacing...
rick31797 is offline   Reply With Quote
Old 06-04-2012, 10:54 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Fridge Problem
yes
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-05-2012, 10:33 PM   #3
Fridge Problem
Can somebody tell me how these compact fridges work.. there are no coils at the back of the fridge... also i dont see any openings inside the fridge for air flow, and i also dont here any fan running.. is this possible, and how do they keep cold..
Old 06-05-2012, 11:15 PM   #4
#1 HAWKEYE FAN
Fridge Problem
they work on the exact same principal as a deep freeze, instead of coils in the back or below the unit they are built into the walls of the box. Next time your refrig is running feel the exterior of the refrig. it will be warm. no fans inside or out.
Old 06-05-2012, 11:27 PM   #5
Missouri Bound's Avatar
Fridge Problem
....and the back of the fridge (inside) should have a panel which is the cooling coil, feel the back of the fridge. The compressor is behind the "hump" at the bottom of the fridge and the coil is right above it.
Do you want it your way or the right way?
Old 06-06-2012, 08:37 AM   #6
Fridge Problem
Ok i get it, i am still not sure the thermostat needs replacing, this fridge is my daughters so i took a look at it yesterday,,,when i got there they had the temp, as far as it could go, and it didnt feel very cold, and the fridge was running,,
I went and got a thermometer too put inside it... when i left the thermometer was in the green, ( the right Temp and the control was set back about 3/4 to full setting..I told them to leave it for a day and dont open the door, see if they need to turn the temp back more to keep the temp in the fridge normal.
One thing i did notice , which may be causing the problem, is there was some ice build up , not alot, underneath the freezer pan, at the back of the pan is the wire for the thermostat.. maybe this is effecting the temp setting..
Old 06-06-2012, 08:57 AM   #7
#1 HAWKEYE FAN
Fridge Problem
there should be no ice or frost build up underneath, if it is touching the temp sensor bulb then yes it will affect the temps. If ice is build up underneath it may be a sign of bigger problems tho
Old 06-06-2012, 09:19 AM   #8
Fridge Problem
Oops, I mistaken thought your refrigerator was without a freezer. Those without a freezer have the cooling coil on the inside back wall while those with a freezer do not, the bottom of the freezer is the cooling coil....so sorry.
Old 06-06-2012, 09:33 AM   #9
Fridge Problem
No problem, thanks for the all the information, i understand whats going on, with it..They have made this so you can keep it tight to the wall,,
Old 06-06-2012, 06:13 PM   #10
Fridge Problem
If there is an ice buildup, unplug for a day or two then plug it back in. You'll need to thaw everything out. possibly a leak or the coils are dirty.
Protocol. is offline   Reply With Quote
problems with fridge clashley General Discussion 9 10-08-2011 07:54 PM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Fridge Diagnosed as "Unrepairable" Old Lady Appliances 9 06-28-2011 07:08 AM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
