Fridge Not Making Ice - Appliances - DIY Chatroom Home Improvement Forum
Old 06-24-2014, 08:42 AM   #1
Rewards Points: 109
fridge not making ice
My FRIGIDAIRE is not making ice and it's leaking in the fridge.
Tek1 is offline   Reply With Quote
Old 06-24-2014, 08:45 AM   #2
Rewards Points: 14,312
Got a model #?
Old 06-24-2014, 11:48 AM   #3
Rewards Points: 109
Originally Posted by joecaption View Post
Got a model #?
Will do later
Old 06-25-2014, 12:15 PM   #4
Rewards Points: 109
Lghs2665kf2
Old 06-25-2014, 05:51 PM   #5
Rewards Points: 358
Could be a couple things going on. Can you pinpoint exately where it's leaking from? A picture would help. How old is the fridge? Thanks.
Please view the links and the parts replacing/testing videos. They may give you more information on how to go about troubleshooting your fridge.
refrigerator icemaker not working
refridgerator leaking water
jmon is offline   Reply With Quote
Old 06-30-2014, 06:04 PM   #6
Rewards Points: 109
I fixed the leak. I am not getting water to the ice maker.
Old 07-02-2014, 11:36 AM   #7
Rewards Points: 358
I would suspect either water inlet valve or the icemaker unit itself.
Click on refridgerator icemaker not working link above and there is a part testing video you can view to check those two items and rule them out. Start there. Just a suggestion.
The Following User Says Thank You to jmon For This Useful Post:
Tek1 (07-02-2014)
Old 07-02-2014, 11:49 AM   #8
Rewards Points: 109
Inlet valve and ice maker were replaced. Im thinking the board since the line to the ice maker not getting any water.
Old 07-02-2014, 01:07 PM   #9
Rewards Points: 358
I' m sure you did, but when you replaced the water inlet valve did you check line with valve open to verify you have water to the inlet valve? Sometimes shut off valve doesn't open all the way or line gets clogged. Also check the water filter, verify its not clogged there.
Basment fridge receptacle JKeefe Electrical 14 12-18-2013 09:30 AM
Water buildup in Fridge mibson Appliances 14 12-05-2013 09:02 AM
fridge leaking water thehvacguy Appliances 2 05-28-2013 07:47 AM
Making room for the fridge ajac201 Building & Construction 3 06-02-2011 10:09 PM
