Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-05-2006, 05:17 PM   #1
Default Fridge not cooling - evap fan?
I have a 2005 Kenmore ColdSpot (Whirlpool 106.xx) top freezer model that mostly stopped cooling in the fridge section last weekend (to 55 F) – freezer still cooled, but showed evidence of melt and refreeze, with frost built up on ice and foods. No great buildup of ice or frost on coils when I took the rear wall off. I did have lots of ice built up on the evap tray and ice blockage about 2-3 inches down the drain tube in the freezer (but have not had problems with water in fridge). Hoped it was just ice blocking the air flow to the fridge, but I have manually defrosted the whole thing and melted the ice blockage, and 24 hrs later still not much cooling in fridge (50 F) and now even freezer seems a little warmer (could just be that it’s empty, though). Also noticed some puddles already frozen in the evap tray again, so I’m thinking the defrost system is working (?) The compressor is running, the fan beside the compressor is running, and the coils underneath are free of dust – so that’s not it. However, I don’t think the evaporator fan in the freezer is running at all – not sure how to test it definitively, but it has shown no signs of life. The fan blades will rotate freely by hand.
I have the Sears guy coming in a week (!) to fix it. Would rather use a local place sooner, but I suppose there’s a chance it could be something still under warranty (compressor only, I think). Any diagnosis thoughts out there, and any chance it’s something a novice could fix? Thanks.
oppiecat is offline   Reply With Quote
Old 12-05-2006, 08:41 PM   #2
jeff1's Avatar
Hi,
Normally test with a volt meter for power to the fan motor leads...power to the fan motor but no go = new fan motor time. No power to the fan motor and we have to check to see where the power is lost.
If the evaporator fan motor is not running, the freezer temp will be effected as well. Having nothing in the freezer will increase the temp some as well.
If over 1 years old, compressor only is under warranty.
106. is the prefix numbers to a full model#.
106.########
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
Old 12-05-2006, 10:31 PM   #3
here's the model # 106.76239401 Thanks for the feedback.
No voltmeter here. Not sure I'm up to trying this one myself. Does the fan sound like the culprit, given those symptoms? Is that an expensive part/labor kind of job?
It doesn't sound like a compressor thing, so my only reason to stick with Sears (ugh) would be to pay for the repair by buying a 1-year warranty, which is more than the repair is likely to be - maybe - but given that an 18 month old fridge is already having problems, maybe not a bad idea? My local guy charges 89 just for the trip charge.
Old 12-06-2006, 08:46 AM   #4
jeff1's Avatar
Definetly a good possibility.
Nope.
Evaporator fan motor
So far, no.
Probably not a bad idea.
jeff.
JRAppliance
www.jrappliance.ca
More On This Topic
Many families have secondary freezers in the garage or basement to store bulk perishable foods. It's a luxury to just walk through a door for a package of meat rather than running to a grocery store, but not when your freezer is on the fritz. Don't chuck... Read More »
Hi I'm Marieve Herington here for Expert Village. And today we're doing easy, quick holiday entertaining. So, I don't know about you, but I think the whole holiday appetizers right out of the box nice and freezer burned, yeah that's really over done for... Read More »
Hi, I'm Rachel for Expert Village. Now I'm going to show you how to prepare the cabbage to be soft enough and able to so we can take the leaf out without tearing it apart. So there are 2 ways. The way that I'm going to show here is I put it in the... Read More »
Hi! I'm Kay and we are filming for expertvillage.com here at Carter's Appliance in Fontana, California. Typically one of the hazards that can occur with refrigerators is that it will not keep the proper temperature. In the event that the refrigerator is... Read More »
How to Build a Pizza
How to Build a Pizza by Expert Village
Hi, this is Richard Buccola here in New York City and on behalf of Expert Village, today I'm going to show you how to take all of that frozen pasta sauce that you have your freezer and show you different ways to make some fast inexpensive pizza where you... Read More »
Evap coil question merlinfolks HVAC 15 07-27-2009 09:20 AM
Can I save my Magic Chef Fridge. The Freezer works but the fridge doesn't bmfay10 Appliances 2 03-28-2008 02:54 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 11:55 AM
Strange Sound from Fridge Blaze25 Appliances 8 12-13-2006 08:39 PM
Refrigerator - stopped cooling??? bragl01 Appliances 3 08-23-2006 11:44 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
