Fridge Leaking Water? - Appliances - DIY Chatroom Home Improvement Forum
Old 07-24-2011, 09:32 PM   #1
Fridge leaking water?
Our side-by-side fridge is leaking water from right below the freezer door every time we use the water in the door - it doesn't seem to do it any other time. Can anyone give me some help on what might be going on? Thanks!
wmdcookes is offline   Reply With Quote
Old 07-24-2011, 10:45 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
its either a cracked tubing going to the dispenser or a loose connection . Take off the kick plate and look for the water lines. You should be able to locate the problem
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 09:51 AM
Leaking Rheem 60 gal Electric Hot Water Heater aklkuno1 Plumbing 3 10-22-2008 10:13 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
Water source from fridge from water heater? dankreboot Plumbing 11 07-12-2008 10:08 PM
