Fridge Help - Appliances - DIY Chatroom Home Improvement Forum
Old 08-08-2013, 07:03 PM   #1
Rewards Points: 29
Fridge help
I am in need of some help. Over the weekend our frigidaire model number 241543933 side by side fridge/ freezer stopped staying cold. The fridge side is still cool but not normal, and the freezer side is the same temp as the fridge side now. I have checked the coils and they are clean. Also, the fan between the compressor and the coils is working. The compressor is warm to the touch but not too hot. Finally, I can't hear a fan when I open the freezer door and the fridge used to make some knocking noises that have now stopped. Any help on this would be great. Thanks!
mkerns12 is offline   Reply With Quote
Old 08-08-2013, 09:20 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
remove the rear panel covering the evaporator coil in the freezer section and check your fan motor, if its not running then it is probably bad.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 08-08-2013, 09:22 PM   #3
Rewards Points: 29
Could that be the problem with the temp on both sides being off? Is it a expensive fix? Thanks!
Old 08-09-2013, 07:47 PM   #4
chitownken's Avatar
Rewards Points: 510
Is possible. Also is relatively inexpensive to replace. The evaporator fan should be running whenever the compressor is running. If the coils are all frosted up and iced, then thaw them out and make sure the drain tube is clear. Frosting up could be the fault of a defective defrost heater, defrost thermostat, or defrost timer/control. If the fan is running and the coils are not frosted, it's time for a service tech.
chitownken is offline   Reply With Quote
Old 08-10-2013, 11:42 AM   #5
Rewards Points: 29
I have a evaporator fan on the way. From the videos I watched, I checked all the other things and they work fine. Hopefully it's the fan!
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Water buildup in Fridge mibson Appliances 14 12-05-2013 09:02 AM
fridge leaking water thehvacguy Appliances 2 05-28-2013 07:47 AM
problems with fridge clashley General DIY Discussions 9 10-08-2011 06:54 PM
Fridge Diagnosed as "Unrepairable" Old Lady Appliances 9 06-28-2011 06:08 AM
