Fridge Is Freezing On The Fridge Side - Appliances - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 09:09 PM   #1
Fridge is freezing on the fridge side
Have a Frigidaire about 5 years old, not sure of the model number. I noticed a few days ago that a can of pop I opened had slushy ice in it. Then yesterday one of the cans literally exploded, and the contents were solid ice. I checked and every can of pop seemed to be frozen solid. So today I bought a thermometer and put it in the fridge on the top shelf. It went to like 20 degrees. I had the fridge side set on a reading of 5. Factory setting is 3. I set it on 5 last summer and it's been there since then. I moved the setting back to 3 and it's still below freezing. Now it's reading about 30 degrees.
One thing I noticed is that it's constantly blowing cold air into it. It doesn't seem to ever cut off. The compressor used to shut on and off so loudly you could hear it pop. I can't hear that popping noise anymore. Any ideas what the problem is, or how to fix it? Thanks
phil74501 is offline   Reply With Quote
Old 05-16-2011, 09:39 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
most likely that control you are turning needs to be replaced
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-18-2011, 05:19 AM   #3
If it's a SxS with a motorized damper- Frigid' has a control kit avail. that thing HW/m refered to-#5303918283.
Jacques is offline   Reply With Quote
Old 05-18-2011, 01:07 PM   #4
It is a SxS. Model # is FRS23R4AW9.
I set the control to 1 last night when I went to bed. It's still reading about 20 degrees.
Old 05-18-2011, 02:05 PM   #5
#1 HAWKEYE FAN
that unit has a motorized damper, your going to have to pull the cover off the damper and see if it is open, closed, or some where in between. if your refrig is 20 degrees it should be closed all the way
Old 05-18-2011, 05:17 PM   #6
Where is the damper? And how do you open it?
Whirlpool Side By Side Not Making Ice Anymore!! handy man88 Appliances 57 07-14-2011 06:33 AM
Installing a water line for a side by side fridge mhp8982 Plumbing 43 09-20-2010 02:21 PM
Ice dispenser flapper door won't close - Whirlpool Side By Side homerb Appliances 2 05-20-2010 07:54 AM
Laying a fridge on it's side mopowers Appliances 2 07-20-2009 03:50 PM
Cathedral ceiling without sofit vent on one side ChrisO Roofing/Siding 3 01-31-2007 10:51 AM
