Fridge Cool, But Not Cold On Highest Setting - Appliances - DIY Chatroom Home Improvement Forum
Old 03-30-2009, 09:29 AM   #1
Fridge cool, but not cold on highest setting
My admiral refrigerator gets cool, but not cold...it's on the highest setting. someone told me to vaccum the coils in the back, which i've done and no change. also leaking a bit of water into the frige.
It's an admiral (maytag) LFT2112ARB top mount refrigerator.
ernivy3 is offline   Reply With Quote
Old 03-30-2009, 10:47 AM   #2
Your problem is that the drain is stopped up. When this happens on top-freezers ice will clog up the air duck that allows cold air into the fresh food section. To fix this remove the back cover off the freezer. Then remove all the ice inside the duct and out. Be careful not to punch a hole in the drain pan. After the ice is gone you must clean out the drain. I do this by forcing hot water down the drain with a turkey baser but you can use any squirt bottle. I have even used the water hose. Then mix water and baking soda and pour it down the drain to prevent this from happing again. If this is not your problem its probably a defrost problem. For more on do-it-yourself appliance repair visit http://www.appliance-repair-it.com
applianceman is offline   Reply With Quote
Old 04-06-2009, 10:35 PM   #3
My apologies for not replying sooner. Your suggestion worked perfectly and solved the problem. Thank youvery much.
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 09:21 AM
Hotpoint freezer cool fridge too cool Maddyrosedad Appliances 1 02-19-2009 06:38 AM
Water from cold water faucet goes from cool to hot to cool tima2381 Plumbing 6 05-22-2007 09:02 AM
