Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 04-24-2008, 12:34 PM   #1
Default Fridge compressor convert to air compressor?
I found info somewhere about converting a fridge compressor into a small quiet air compressor for small airbrush use. I can see how it would compress air as well as it does freon and I believe it would be nice and quiet compared to most compressors.
But I thought the fridge compressors needed to be on a closed loop system to keep from losing oil??? Are there any experts out there who can tell me if a fridge compressor will hold up when converted to pump air? Isn't the oil on one of these compressors right in with the freon?? Would you have to keep adding oil somehow? I'm not worried so much about oil in the compressed air because I can put a filter on to filter the oil out of the compressed air before it goes to the airbrush.
I have an old ugly fridge I no longer want that is physically in very bad shape but still runs cold and I am looking for a small quiet compressor for a small pencil type airbrush. I already have a good pressure tank/switch etc. from one of those extremely noisy airless compressors but the compressor itself bit the dust.
I would just go ahead and do it but I don't want to release the freon into the atmosphere so I'll need to pay a pro to pump out the freon. Before I do that I'd like to have some confidence that it will actually work for a while.
Old 04-24-2008, 03:10 PM   #2
jeff1's Avatar
Hi,
I am absolutly 100% no expert for that!
For the most part, correct. Compressor is filled with oil and some oil would travel around through the system with the refrigerant gas.
For a while I would suspect. In a refrigerator the compressor compresses a vapour refrigerant. Air is mostly a vapour/gas but has moisture in it and the compressor cannot compress a liquid and water vapour often makes an acid in the compressor. Newer 134A compressors use an oil that is contaminated in approx 30 minutes when exposed to air and water vapour.
Probably worth trying.
JMO!
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
More On This Topic
Let the spraying begin! Create art and illustrations by using airbrushing techniques and materials. You will need an airbrush and compressor, as well as a cache of materials to have fun with this form of art. Many art and craft supply stores provide the... Read More »
What is an Air Compressor?
What is an Air Compressor? by Expert Village
Hi, this is John on behalf of Expert Village. In this video clip I'll be answering the question, what is an air compressor? An air compressor is a tool used in many various trades. The purpose of an air compressor is to supply compressed air to other... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I'll be talking about what an air compressor does. As it's most basic function the air compressor will bring in air from outside it will process that air and it will supply these tanks with... Read More »
Air Compressor Maintenance
Air Compressor Maintenance by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip I'll be talking about air compressor maintenance tips. Before you preform any maintenance task you first need to turn the compressor off, unplug the compressor, drain the tanks, and let your... Read More »
Hi, my name is Mark Delgado with American Auto Service for Expert Village. Leaks can occur from any part of the system. The compressor may be kicking on but it could be leaking. It's a major source for leaks as are the lines. The condenser is exposed to... Read More »
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 01:17 PM
air compressor - dangerous???? reds_21 General Discussion 23 04-26-2008 12:17 AM
Air Compressor Timer 69-er Electrical 7 10-02-2007 05:40 PM
Air compressor and framing nailer for DIY ADKstorm Tools 18 01-19-2007 04:21 PM
Fridge not cooling - evap fan? oppiecat Appliances 3 12-06-2006 08:46 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
