Fridaire Ele Slide In Stove - Appliances - DIY Chatroom Home Improvement Forum
Old 09-30-2013, 09:25 PM   #1
Rewards Points: 20
Fridaire ele slide in stove
Oven was on preheat and pow, the 100 amp main breaker tripped. The upper top element still works after resetting the breaker. The preheat controls still light up, but get no heat from the bake element. I disconnected the leads to the bake element and get a 21.5 ohm reading.
Not sure what is normal. I tested for shorts on the incoming hot leads and they are ok. The stove is hard wired in a j-box and don't think the problem can be their because everything else is working normal.
The only thing else that may have a problem are the oven controls or a surface unit switch which is on the schematic. Any suggestions?
model # is FEF352ASF
Thanks Emmy
emmy is offline   Reply With Quote
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Do you have a Wood/Pellet Stove Insert with a Raised GRANITE Hearth? gmoom Remodeling 1 01-24-2011 04:54 PM
Wood Stove, and Furnace hot water system shendog HVAC 7 10-04-2010 09:30 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 05:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
