Freezer Workers Not Frige - Appliances - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 09:50 PM   #1
freezer workers not frige
what can be wrong
rictorres123 is offline   Reply With Quote
Old 01-13-2012, 05:51 PM   #2
Crusty Old Dude
Big Stud's Avatar
I don't know if this is what has happened to you................ but here goes. I have the same problem right now with my Maytag wide by side. I discovered that the cooling coil in the freezer was all iced up and the passage that brings cold air into the refrigerator was iced up as well. My guess is that my defrost timer is not working and thus not defrosting the freezer when needed. I have defrosted the freezer twice now manually and my guess is that it will continue to happen till I get a repairman in here to fix it.
Try defrosting your freezer by unplugging it and using a hair dryer on the coil in the freezer compartment till no water drips off of it. This will work till it needs defrosting again (about a month or so). Best to get a repairman to look at it asap. BTW ... you may have to remove the panel inside the freezer on the back to see the cooling coil,
All the best to you and yours, Tom
Big Stud is offline   Reply With Quote
frige stopped cooling but freezer still works. 1196 kenmore coldspot. defrosted freezer as ice granules on all interior stuff. Dmanyhorses Appliances 2 11-15-2011 12:06 PM
kenmore fridge too warm, freezer iced up tarbash11 Appliances 5 06-30-2011 11:32 PM
Kenmore 596 bottom freezer cold top warm klimshelf HVAC 2 03-30-2011 09:32 AM
freezer side of frige keeps freezing up rdbm1945 Appliances 1 12-21-2009 09:16 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
