Freezer Stops Working Then Slam Door It Works Again - Appliances - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 10:44 AM   #1
freezer stops working then slam door it works again
what are the most common causes for the freezer to stop and then when you slam the door it comes on again and also the refrigerator freezes food on the top shelves
MRHANNA is offline   Reply With Quote
Old 01-25-2012, 10:54 AM   #2
MarginallyQualified
Rewards Points: 2,464
You may have a loose connection somewhere.
Start with using an extension cord to plug it in in somewhere else.
If that solves the issue then open the receptacle box and look for a loose
wirenut or loose wire on the device or loose jaws within the device.
ETA: If not... then the (still likely to be a loose connection) problem is inside the machine.
The Following User Says Thank You to TarheelTerp For This Useful Post:
MRHANNA (01-25-2012)
Old 01-25-2012, 07:32 PM   #3
sleepyg's Avatar
Rewards Points: 26
I think the problem is in the thermostat if it is freezing the food on the top shelf too. Check the thermostat settings and look at the connections.
sleepyg is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
frige stopped cooling but freezer still works. 1196 kenmore coldspot. defrosted freezer as ice granules on all interior stuff. Dmanyhorses Appliances 2 11-15-2011 11:06 AM
Can I save my Magic Chef Fridge. The Freezer works but the fridge doesn't bmfay10 Appliances 2 03-28-2008 12:54 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 08:53 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
