Freezer Side Frosting/refrigerator Side Not Cooling - Appliances - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 04:24 PM   #1
freezer side frosting/refrigerator side not cooling
I have a kenmore refrigerator S/S model#10657074602, the freezer in some areas have frost buildup and the refrigerator not cooling, I replaced the door seals on both doors about 1 month ago and still the same problem is happening, I notice the air flow vent in the refrigerator side has ice build up. Need some tips please... about to purchase a new appliance due to frustrations but if I'm able to hold on to this unit for awhile longer, it would be great thanks for the help
GCastillo is offline   Reply With Quote
Old 03-23-2013, 04:28 PM   #2
Rewards Points: 13,690
Check to make sure the fan is working.
http://www.repairclinic.com/RepairHe...rm-10657074602
Old 03-25-2013, 10:29 AM   #3
Your defrost system isn't working. Too much frost in the freezer restricts the air flow into the fridge. Check your defrost thermostat and heater.
jfrotten is offline   Reply With Quote
Old 04-06-2013, 03:37 AM   #4
I went through the same issue with my fridge....
I changed thermistors, thermostat, heating element, and finally motherboard. All in all cost less than 130$ for parts, i didnt pay retail for the parts. I had no idea on how to do anything when this happened. Just googled my model number and symptoms, found a tutorial or video that explained on how to trouble shoot different problems.
This was a while ago, and memory is fuzzy... Basically the heating element is not coming on and defrosting, causing the build up of ice and warming the fridge side... Caused by either faulty thermostat, thermistor, or motherboard etc. To troubleshoot which it is, you will need a multi meter and test continuity of each system and certain points of motherboard and such... Big pain in but, that's why I replaced it all rather than test everything.
If you live in a big city, find a appliance store and get the parts to fix yourself. They will hopefully be real helpful and give a discount..
xxxshiftxxx is offline   Reply With Quote
Old 04-08-2013, 03:50 PM   #5
Rewards Points: 744
Whoops, Joe beat me to it.
Seattle2k is offline   Reply With Quote
Summit ff1415ss; freezer cools bottom is not cooling Foxtrot Appliances 2 02-22-2013 07:53 AM
Frigidaire side by side freezer works refrigerator doesn't! Towerdog2 Appliances 11 07-22-2012 09:26 PM
Cape cod side attic insulation problems (fun) capecodfun Building & Construction 1 01-27-2011 01:49 PM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 10:02 AM
GE side by side refrigerator not cooling joedadog Appliances 2 01-15-2009 11:23 PM
