-   -   freezer side frosting/refrigerator side not cooling (http://www.diychatroom.com/f47/freezer-side-frosting-refrigerator-side-not-cooling-175326/)
GCastillo 03-23-2013 05:24 PM
I have a kenmore refrigerator S/S model#10657074602, the freezer in some areas have frost buildup and the refrigerator not cooling, I replaced the door seals on both doors about 1 month ago and still the same problem is happening, I notice the air flow vent in the refrigerator side has ice build up. Need some tips please... about to purchase a new appliance due to frustrations but if I'm able to hold on to this unit for awhile longer, it would be great thanks for the help
joecaption 03-23-2013 05:28 PM
Check to make sure the fan is working.
http://www.repairclinic.com/RepairHe...rm-10657074602
jfrotten 03-25-2013 11:29 AM
Your defrost system isn't working. Too much frost in the freezer restricts the air flow into the fridge. Check your defrost thermostat and heater.
xxxshiftxxx 04-06-2013 04:37 AM
I went through the same issue with my fridge....
I changed thermistors, thermostat, heating element, and finally motherboard. All in all cost less than 130$ for parts, i didnt pay retail for the parts. I had no idea on how to do anything when this happened. Just googled my model number and symptoms, found a tutorial or video that explained on how to trouble shoot different problems.
This was a while ago, and memory is fuzzy... Basically the heating element is not coming on and defrosting, causing the build up of ice and warming the fridge side... Caused by either faulty thermostat, thermistor, or motherboard etc. To troubleshoot which it is, you will need a multi meter and test continuity of each system and certain points of motherboard and such... Big pain in but, that's why I replaced it all rather than test everything.
If you live in a big city, find a appliance store and get the parts to fix yourself. They will hopefully be real helpful and give a discount..
Seattle2k 04-08-2013 04:50 PM
Whoops, Joe beat me to it.
