Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-12-2008, 04:37 PM   #1
Freezer not freezing
I've got a fridge/freezer in the garage that has two jobs: cool beer and freeze deer. I came home last night with a fresh case to go in the fridge and I smell venison, when it hits me... frozen food shouldn't "smell" like anything. I open the freezer to see about half of the 50lbs of venison in there thawed out, the other half is getting there.
I had the temp setting at about 3/4 to coldest so I turned it all the way. The fridge and freezer are about the same temp now; not warm but definitely not cold enough. The blower is blowing but the air isn't cold enough. I read a few threads about low coolant not always being the issue so I'm curious what your thoughts are? Its not new by any means, and has worked excellent up to this point. Thanks!
moneymgmt is offline   Reply With Quote
Old 05-12-2008, 08:22 PM   #2
jeff1's Avatar
Hi,
No make or model# posted.
Some simple things to check...
http://www.applianceaid.com/frig_notcold.html
http://www.rd.com/familyhandyman/content/17790
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 05-13-2008, 08:32 AM   #3
Thanks for the reply Jeff, I'll have to pull the make and model tonight. When I checked it last night it was running but blowing warm air. The cool air the day before may have been from the still somewhat frozen food.
Old 05-13-2008, 08:44 AM   #4
jeff1's Avatar
As always we would go what is working and what is not....evaporator fan motor working, condensor ( if used ) fan motor working, compressor working?
Any strange noises ( clicking, buzzzzzing, ect )?
jeff.
JRAppliance
Old 05-30-2008, 12:40 PM   #5
Hi, one of the main reasons is to make sure that there is not dust bunnies in the coils. Take time to use a coiling cleaning brush ( looks like a tapered bottle brush) and brush clean the coils and also use a vacume cleaner too. They told us in school to remember-- AIR FLOW AIR FLOW AIR FLOW--. This worked when my air conditioner was only blowing warm air.
bugzee is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 40 10-15-2010 11:38 PM
Kitcheaid Freezer wiring Harness replacement db819 Appliances 2 03-11-2008 10:55 AM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
Dedicated freezer circuit in basement? budde97 Electrical 5 02-15-2007 04:09 PM
Ice on freezer door Dusty Appliances 6 10-15-2006 01:09 AM
