Freezer Is Hot At The Bottom - Appliances - DIY Chatroom Home Improvement Forum
Old 05-08-2016, 08:45 PM   #1
Rewards Points: 30
Freezer is hot at the bottom
Hi all, I have a side by side fridge and the bottom vent of the freezer, where the water filter is, is emitting really hot air, making the floor really warm. What can I do about this?
wendymoore is offline   Reply With Quote
Old 05-08-2016, 08:49 PM   #2
Rewards Points: 13,300
Re: Freezer is hot at the bottom
Nothing, that's the way a refrigerator works.
Old 05-08-2016, 08:51 PM   #3
Rewards Points: 30
Thats weird, its never done that before and I have lived in this house for over a year. Odd.
Old 05-08-2016, 09:04 PM   #4
Rewards Points: 230
As Joe mentioned, that is the way they work. You could try cleaning the coils and see if that helps. Most are located on the bottom now. You'll need a shop vac with narrow attachments and long narrow brush. Just a suggestion.
jmon is offline   Reply With Quote
Old 05-08-2016, 09:07 PM   #5
Rewards Points: 30
ok thanks!
Old 05-31-2016, 03:16 PM   #6
Rewards Points: 1,442
You might not have noticed when it was colder out. Now that it's getting warm it may be more noticeable.
mikegp is offline   Reply With Quote
Old 07-17-2016, 12:55 PM   #7
Rewards Points: 26
i think it's normal, my little fridge when touching the bottom, you feel it's pretty warm
samguan is offline   Reply With Quote
Evap replaced on bottom freezer Amana fridge Plumber101 Appliances 8 03-24-2015 10:48 PM
Attach Tapco Steel Adjustable Building Column to beam and bottom plate dropedBeam007 Building & Construction 8 10-13-2014 09:46 PM
Kenmore 596.75503400 bottom freezer Lake bums Appliances 5 09-03-2014 06:38 PM
Kenmore Bottom Freezer Ice Maker Bar Ranny44 Appliances 0 03-24-2012 01:44 PM
Ge profile double door bottom freezer dukas Appliances 5 01-17-2011 04:39 PM
