Freezer Drain - Appliances - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 07:59 AM   #1
Rewards Points: 79
Freezer Drain
I have an older Frigidaire upright freezer and about every there months I have to defrost the freezer drain line (to defrost pan under freezer). She ices up to point of water frezeing inside of the freezer. I go in with a blow drier and ice pick and thaw everything out, run my compressor at 50 PSI and blow line out, then put an 1 OZ of houseshold blech down the drain and and all is well for a few months, I do put 1 OZ of household bleach in the drain every month but that does not seem to work. Suggestions?
vabear is offline   Reply With Quote
Old 02-29-2012, 07:42 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
when I run into these I like to make a heat transfer strap and put it down the drain hole, works every time. Get yourself a piece of #9 wire about 6" long. Make a loop on one end then slide the other end down the drain tube a couple inches, now wrap the loop around the defrost heater and cinch it tight so it makes good solid contact with the heater.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-29-2012, 08:10 PM   #3
Rewards Points: 79
Drain Freezeup
Let's make sure I understand, the wire is indsice the cabinet and one end goes down the drain port/tube and other end connects to heater. Isn't the heater outside the cabinet, and how do I get through the cabinet to that.
Old 03-01-2012, 09:51 AM   #4
Rewards Points: 79
Drain Freezes
Well duh color me old and slow but I finally realized if I pull the access panel in the cabinet all is visible. Now all I have to do is identify the heater, I have a schematic but am clueless in relationship to the evaporator where is the heater located, can you help me here, where should I be looking?
Old 03-01-2012, 11:57 AM   #5
#1 HAWKEYE FAN
the heater is a directly underneath the evaporator coil
Old 03-01-2012, 12:00 PM   #6
#1 HAWKEYE FAN
to clarify, the heater is attached to the underside of the coil
Old 03-01-2012, 12:10 PM   #7
Rewards Points: 79
Freezer Drain
OK now I am seeing a bit more clearly. Do I need to pull the evaporator coil forward to access the heater or take back off of freezer to come in from behind.?
Old 03-01-2012, 06:06 PM   #8
#1 HAWKEYE FAN
not sure that you are following. Inside freezer, take the panel off that covers the evaporator coil. You should be able to see the heater at the bottom of coil. Do not do any thing to the coil, just wrap your wire around the heater and cinch it tight.
Old 03-01-2012, 06:11 PM   #9
Rewards Points: 79
Freezer Drain
Bear with me I am old and slow. I di remove access panel and Voila there was everything. On my freezer there is a cover guard over the heater that I assume snaps off and the heater itself I am almost certain is glass. How does that change things, still carefully bend wire over the galls heater and then down into the drain port, correct.
Old 03-01-2012, 10:28 PM   #10
#1 HAWKEYE FAN
post the model#, I don't recall ever seeing a Frigidaire with a glass tube heater. If it s glass hold everything.
Old 03-02-2012, 08:38 AM   #11
Rewards Points: 79
Freezer Drain
I am an idiot, it is a Whirlpool EV200NXEN00, the Refrigerator next to the freezer is a Frigidaire. She is a Glass tube with a cover guard that I assume snaps off to access the heater.
Old 03-02-2012, 09:27 AM   #12
Rewards Points: 79
freezer Drain
Another thought since there is a metal guard around the glass heater could I just hook the wire to the cover guard (it must get fairly hot) and run that down the drain?
Old 03-02-2012, 05:33 PM   #13
#1 HAWKEYE FAN
no probably not, be very careful around that glass tube heater it is very fragile. Your only alternative now may be an auxiliary drain tube heater that gets hooked to power off the fan motor.
Old 03-03-2012, 09:36 AM   #14
Rewards Points: 79
freezer Drain
I did access the shield and it appears to rotate (guess it snaps on a rod at the end of the heater). So I can unsnap the shield and then access the heater tube, however is the shield full of holes so my copper wire will just drop through a hole and go down the drain, or will I need to be more creative here?
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
