Freezer Coils Ice Over And Thermostat Always Has Continuity - Appliances - DIY Chatroom Home Improvement Forum
Old 01-13-2014, 06:55 PM   #1
Rewards Points: 37
Freezer Coils Ice Over and Thermostat Always Has Continuity
I have a GE side by side. My freezer coils ice over about every 1-2 months. It makes the fridge warm. I've been defrosting the coils with a hair dryer, which buys me some time before it occurs again, but I'd like to permanently fix the problem.
I bought a new thermostat (the one that sits at the top of the coils) and wired it in. It'll take some time before the coils either ice over (or not) so I don't know if the thermostat was the problem. Hence, I'd like to test the old thermostat to see if it was defective.
From what I understand, if I check continuity on a thermostat, I should get continuity across the wires if it is cold, but not if it is warm. Well, I've tested my old thermostat while it was freezing and also while it was room temperature. Either way it passes for continuity.
This confuses me, as I assumed that when it passes for continuity, the circuit is complete and the defroster would run. That makes it seem like the defroster would run 24x7, which would mean no frost on the coils (and maybe some other problems). I expected to see no continuity, and therefore no defrosting. Am I understanding this wrong?
I'm not quite sure how to determine if my old thermostat is defective.
ed3120 is offline   Reply With Quote
Old 01-13-2014, 07:32 PM   #2
Rewards Points: 37
My fridge is a GE GSL25JFPBS. I understand that I should also check the defrost timer, but I can't seem to find it. Does anyone know here it is? The manual doesn't say.
Old 01-13-2014, 09:07 PM   #3
First, I am no expert but someone else grappling with similar problems. But I would guess that one possibility is that giving continuous continuity the defrost heater burned out. If you have a vom you can test it but not sure of details.
You can look for my post if you want to admire someone even deeper in the mire than yourself.
Richardvmt is offline   Reply With Quote
Old 01-14-2014, 02:36 PM   #4
Rewards Points: 37
Yeah. I'm not sure how to find evidence that the defroster has come on or not, besides waiting for frost buildup.
