Is This Forum For Refrigeration Too? Ice Maker Problems - Appliances - DIY Chatroom Home Improvement Forum
Old 02-28-2010, 04:58 PM   #1
Rewards Points: 107
Is this forum for refrigeration too? Ice maker problems
Sorry if this forum is not for refrigeration also. If inappropriate moderators please delete. I just bought a new Kenmore refrigerator model #253.7480240H. I noticed it is not making ice. It turns out it is not cold enough to freeze. I had the thermostat set to "normal" and today set it to its coldest setting. The fridge is set to about the 3/4 mark. It does manage to make about 1 round of ice per day. This fridge and freezer are empty if that makes any difference. I did put a can of soda in the fridge and it is cold. Tomorrow, when I go over there I will take a thermometer with me and check the temp. Will being empty make a difference on how this works. TIA
thunderhead is offline   Reply With Quote
Old 02-28-2010, 05:05 PM   #2
BJ
The refrigerator and frezer are seperate
If you just bought it, time to call the repaire sevice out. The cooling for the fridge and the freezer are "kind of" seperate units. There could be a number of things wrong with the freezer side such as the thermostate having gone bad.
BJLower is offline   Reply With Quote
Old 03-01-2010, 04:56 AM   #3
An old Tradesmen
Rewards Points: 8,202
I moved your thread to the Appliance forum. Where it is more appropriate.
Empty freezer and fridge is probably part of your problem.
Air doesn't hold heat as well as food does. So it can't get the water as cold as it needs.
Old 03-01-2010, 05:00 AM   #4
An old Tradesmen
I don't do resi frig anymore.
But. I ran into this too. The ice maker gets accidentally connected to the hot water pipe.
Multiple problems in 3 year old house I just purchased swenard Plumbing 12 08-31-2009 03:53 PM
GE Ice maker problems dee1215 Appliances 2 05-17-2009 08:19 AM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 08:02 PM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 02:04 PM
