Floor Dryer Vent Won't Allow Enough Room For Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 04:50 PM   #1
Floor dryer vent won't allow enough room for dryer
I have a dryer vent that comes up out of the floor about 4 1/2" from the back wall of the utility room. Because it sticks so far out into the room (a total of nearly 9&quot, there is no dryer that will fit in the space and allow the door to the room to close. I pulled up the laminate and found the reason, a floor joist running parallel to the back of the dryer. Is there a way to move the vent or is there some adapter?
kay-d is offline   Reply With Quote
Old 07-11-2012, 05:50 PM   #2
Rewards Points: 52
Is the duct such that you could position the washing machine and dryer on either side of the duct? If so, most dryers allow the option of rear or side venting.
Old 07-11-2012, 06:10 PM   #3
Rewards Points: 13,274
Is the dryer on an outside wall?
Old 07-11-2012, 10:54 PM   #4
Missouri Bound's Avatar
Some pictures would be great. You have tore up the floor, now can you move it?
Do you want it your way or the right way?
Old 07-13-2012, 04:09 PM   #5
Rewards Points: 29
Check the instructions on the drier, sometimes the vent can internally be turned to go out the back, side, or bottom. If you can turn it out the bottom maybe you can be lucky enough to be right over the vent.
cube17576 is offline   Reply With Quote
furnace room vent dtw HVAC 4 10-30-2011 02:25 AM
One room cold- what pipes are what...help cciampi HVAC 24 02-20-2011 12:44 PM
Laundry Room Vent: slope up - then down LogDog Plumbing 3 12-31-2010 05:59 PM
tap into vent and run extra vent to room? denemante HVAC 0 11-11-2010 04:55 PM
installing a vent in the door to my hvac room brentjc HVAC 1 10-13-2010 07:10 PM
